Grooved pavement sucks on bikes. Period. For what it's worth, every bike I've ridden on grooved pavement has been a sketchy ride. Sometimes white knuckle scary. My '58 Trailblazer only has a slightly more osculation with a ribbed front tire than my '83 Suzuki with dual sport tires did. The first few rides on my Suzuki on grooved pavement were quite unnerving. My friend told me to beware of the grooved pavement, but I didn't realize how unpredictable it really is. No matter what tire/tire pressures you run, I think you're going to find yourself with the same problem.
I've found that keeping a "motocross" body position on grooved pavement really helps keep the bike stable. This will not eliminate the osculation, but it help you feel more in control of your bike.Sit upright on your seat with a slightly aggressive stance, but not to where you're exerting lots of energy to keep in the position. Next, you need to change how you hold onto the handle bars. Instead of just casually holding on or giving the bike "the death grip", keep you chest, shoulders and elbows square with your elbows pointing upward and outward. If were to look at yourself straight in a mirror in this stance, you should see a rectangle formed between your chest, arms and handle bars of the bike. While in this position, you want to keep elbows solid, BUT NOT LOCKED! You will find that boxing your arms and chest over the handle bars greatly reduces the
opportunity for the bike to want to "walk" where ever it wants.
Notice how even when airborne, the rider keeps the "boxed" position
Boots - Give this technique a try and let me know if it helps you or not.
