Hitting 100 will be pretty close to a miracle, but I think it's possible.
It will need cams and headwork to do it, along with a likely need for some re-mapping of the ECU.
It will have to be about as strong as the Fireball to make the Ton.
This means we have to double the stock hp at the rear wheel.
That's not so easy.
It's a lot easier to say it, than it is to actually do it in the real world.
Sorry to weigh in late on this, but I just got back tonight from another extremely painful dyno run
The power commander only attaches to the injector and the TPS, you cannot change the rev limit, so any power gains must be made in the stock rev range.
My PCV unfortunately was probably put together at around 4:30 on a friday afternoon, as there is a major issue with the PCV reading the revs, and will randomly spike from 9000 to 12000 rpm while cruising at 3500, so I can't offer real world figures on gains yet.
However, The secret to making power on the UCE as far as I can see is the intake length.
I am currently running a straight through SS pipe with a restrictor right at the end of the tail pipe and a K&N filter. When the filter was mounted direct to the throttle body, using the stock ECU, I made 20RWHP, when I introduced two 45degree elbows and a 50mm pipe, the RWHP jumped to 24HP, Unfortunately I ran out of time, but from all accounts, an intake of similar length to stock, should provide even more.
Once I get the replacement PCV, I will do runs at both 50mm and stock length with the two elbows.
And ACE, I still believe the biggest hurdle in hitting the ton is the gearing, a 19 front sprocket isn't enough to get you there, and as you can't go bigger without some case surgery, or get a smaller rear sprocket, your only option is tyres or tyre and rim
