Ah, there is a misunderstanding, I refer to buying the parts and using the lathe for alignment. Normally a truing stand (adjustable dead centers) would be used for this but a decent lathe will work also. This is not covered in any of the RE manuals that i have seen,but if you get a hold of some Harley bottom end info it would suffice. It's pretty straight foreward, the assembly should run true on all axes,while rotating between centers. This is usually done by slowly tightening the crankpin nuts while indicating the runout of the assembly,until the nuts are at the recomended torque. Dont be afraid to hit it!!(see harley info it's amazingly brutal)
