Hi again. Over the last couple of days I suspected that my G5 was idling higher than usual. Yesterday after getting back from work, turning up the driveway in first gear the engine started to rev to about half throttle, with the throttle closed. I stopped it in the shed and then started it again, same result with the engine revving constantly way above idle. As it was getting dark I quickly checked the throttle cable but could not see any problem. Any similar experiences or thoughts? The bike is an '09 G5 with just under 15000 kms on the clock. It had a full service and check over at 12000 kms. It has been running an indirum spark plug since about 5000 km if that makes any difference.
Regards
Hocko
