Decided to put little mirrors on my Bullet. The ones in the attached picture are 3 inch diameter aftermarket pieces. They are poor quality.. but maybe they'll last for awhile. The adaptors were made useing 7/16 fine thread bolts that were drilled and tapped on the inside 5/16-18. The stock mounting lugs on the bars is 10mm-1.25mm pitch metric. They were drilled out and tapped for the 7/16 gringo thread bolts. The bend in the stems was increased to bring down the mirrors so that they are now rather close to the handlegrips. That makes it so that they are almost useable if I tuck in my arm.
