Thanks for all of your comments. Sorry it's taken me a few days to get back to you. Work has been crazy.
The recovery hasn't been too bad. I think I fared better than the bike. My hands are back to normal and other than some general soreness in the obvious areas for the first day or so, I feel ready to do it again. I ordered a 7" headlight and the bolt for the tank from my local dealer. I'll stop at radio shack and grab a new lug to crimp on the negative lead. I think it'll be back to 100% by next week.
I promised to share some thoughts on the bike, so here goes.
1. The front wheel seems to be unbalanced. There is a definite shaking that occurs at certain speeds, mostly above 65 mph. I can see the front wheel hopping up and down. If memory serves, there are small weights that can be clamped on the spokes to balance the wheel. I will look for a balancer and will gladly take recommendations if any of you have experience with a particular model (good or bad).
2. There is a slight pulsation when applying the front brake, like it's slightly warped. It's not too bad, but definitely noticable. It was there before the ride and doesn't seem to have gotten any worse, so I'll probably live with it until it changes. On the topic of brakes, I see some folks have put a stainless steel braided line on their bikes. Where can I get this? I find the front brake unbelievably weak.
3. On a long ride, being able to change seating positions is key. Sometimes I moved my feet to the passenger pegs. Within a few seconds, this caused an oscillation in the bike, like the front end wanted to go one way and the rear end wanted to go the opposite. It felt like riding a high speed snake. This happened at speeds as low as 60 mph. I also tried extending my legs and resting my calves against the front of the driver's pegs. This also caused a wobble. Even the standard seating position caused a wobble, but only over 70 mph. I found that shifting my weight way back (sitting half on the passenger seat and half on the driver's seat) would keep the bike stable. The speed limits on a large part of the ride were 75 mph, so traffic was going 80-85. I had to catch a draft just to keep up with the slow cars. I wonder if the unbalanced front wheel has something to do with it, or if I should look into a fork brace or steering damper. It almost felt like the frame was flexing. I've felt that on other bikes, but mostly when hitting a bump mid-corner. On my old Honda ST1100, the common fix for the 45 mph wobble was to replace the stock ball bearing in the steering stem to a tapered roller bearing. Is this behavior common on these bikes, or is there something wrong with mine? It is a C5 Special with the straight fork legs. Could different tire pressures help?
That's about all I've got for now. I look forward to hearing your feedback.
