White Bitch RIP
37 Guests, 2 Users
gizzo, Sectorsteve
February 14, 2016, 03:07:52 pm
Author Topic: tire pressure with sidecar on  (Read 1699 times)
AwL
« on: July 23, 2012, 08:26:05 pm »
What tire pressure is recommended for bike -2009 G5 - with sidecar attached?  Thanks, Al
The Garbone
  • Shade Tree
  • User Complaints: 22
Re: tire pressure with sidecar on
« Reply #1 on: July 24, 2012, 06:12:41 am »
30 rear, 25 front, 20 side.
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
Thumper
  • Psalm 23
  • Classic Wannabe
« Reply #2 on: July 25, 2012, 07:10:12 am »
In my experience with many different types of hacks (Urals, Yamaha 650/Velorex, old '75 Goldwing/Velorex, HD Nightster/Cozy) - this is a general rule for me:
Max (or near) pressure on the tires - all three.
And that is based on the manufacturer's max pressure on the sidewall.
The sidecar is a load on the bike - and as with any large load, to increase tire pressure is a good thing.
And that can be very different - my Cozy pressure is 33 psi - with the Metzler - but *not* so with the stock Indian tire that came with it - and now serves as the spare. (see http://mysite.verizon.net/respud62/id10.html)
The Garbone
  • Shade Tree
« Reply #3 on: July 25, 2012, 01:23:58 pm »
Well, it has to be mentioned that bike and riders differ as well as the toe and lean of the rig and tire type.  All affect the ride of the hack.   I have found the above pressures to work on my rig in that the machine turns well and tracks properly down the road with those pressures.
I usually keep the rear pretty hard as it is that tire that scrubs the most in turns etc.   I also found the car to be too bouncy and unpleasant at 30 lbs.
Gary
57' RE Crusader 250
67' Ford Mustang
01 HD 1200 Custom
07 RE 5spd HaCK
AwL
« Reply #4 on: August 02, 2012, 06:55:11 pm »
Increased tire pressure to 30 front/rear, and 25 sidecar.  Rode better with less wobble prior to installation of steering damper.
