So, last night when trying to start my bike, the lights came on, fuel pump kicked in, and then when i hit the start button everything went dead. I turned the key off, tried again, and nothing...so, after a brief inspection of possible causes, I realized that some how, the ground wire to the negative terminal on my battery had somehow snapped at the point where it actually meets the wire, (see photo).
So, i was thinking easy fix; just run to the hardware store, grab a connector that will fit on the negative terminal to the battery, connect it to the ground wire, and be done with it.
But before doing that, i figured I'd check with everyone to see if:
a) am I not thinking of something that might cause a short or is there a certain gauge wire connector I should make sure to use, and;
b) has this happened to anyone else?
I'm dumbfounded how this could have happened; no pressure on the cable and there wasn't any corrosion or anything amiss i could see about the battery, battery cover, ect.
As always, any input would be greatly appreciated.
Adam.
