Author Topic: Pilot light goes out?  (Read 5798 times)
Jamesriot
  • Four wheels move your Body, Two wheels move your Soul
on: July 14, 2012, 04:28:59 pm
Good day everyone,
Last week I have sent my C5 Black Chrome for a first time service, now the problem starts to arise.
A few weeks ago I found a little pilot lights between above the headlight was out. This afternoon I send my bike to the service center for repair. But Just now after  I put some milage on it a few kilometers, the problem arises again, the pilot lights goes out and came back again frequently.
If there is anyone who has experience and same problem, hopes to share it here or possible solutions.
Thanks!
« Last Edit: July 14, 2012, 04:37:27 pm by Old Holborn »
RE Black Chrome 500 EFI
Modenas Elit 150
HD Sportster 883
Modenas Elit Sport 150
Kawasaki Vulcan VN800
MZ Moskito 125
Suzuki TXR 150
Honda cup c70
Hobbydad
  • aka Mike
  • Your only as old as you feel
Reply #1 on: July 14, 2012, 04:59:42 pm
One of the small bulbs above the headlight, correct? You can easily remove the screw holding the clear cover in place and inspect the bulb. It may be loose in it's socket, or the bulb filament may be bad and the bulb needs replacing. If it's in there tight, and the filament looks good, then you may need to check the wiring connections behind the headlight. Again, the headlight is also easily removed with a screwdriver. Just follow the wiring from the bulb socket to it's plug, and look for anything loose. My bet would be on just a bad bulb.
'11 C5 Military
Maturin
  • My Precious
Reply #2 on: July 14, 2012, 05:10:51 pm
Mine is eating these. I put some self-made LEDs in, they last a little longer. But only a little  ;D
2010 G5
Walter Röhrl
Hobbydad
  • aka Mike
Reply #3 on: July 14, 2012, 06:09:31 pm
Yeah, I replaced mine with LED's from superbrightleds.com, very happy with them.
'11 C5 Military
Reply #4 on: July 14, 2012, 07:18:25 pm
Those little bulbs are one of the few things that failed during my first year of ownership of my G5.
A couple of good Silvania bulbs seems to have solved the problem for the last 8 months.
singhg5
Reply #5 on: July 14, 2012, 07:28:55 pm
LED bulbs for pilot lights work very well.
http://www.youtube.com/watch?v=hMCSEraYCxM
1970's Jawa /  Yezdi
2006 Honda Nighthawk
2009 Royal Enfield Black G5
busmec
Reply #6 on: July 14, 2012, 08:57:17 pm
I had same type problem on my bike . What I did was a I took the bulb out of socket & bent the grounding tab in just a little bit to make better contact on the bulb , that took care of problem. Are they some tpye of running lights for when your headlight isn't on?
Reply #7 on: July 14, 2012, 09:38:48 pm
Yes.
If you are riding a U.S. import you can modify your wiring harness to remove the headlight jumper inside your headlight casquette.
That will restore your lighting switch on the right handle bar to something that actually operates the lights.
It has three positions.  Off, Parking/running lights and tail light and the headlight/running lights/tail light position.
BrashRooster
  • Yeah I stepped in it.
Reply #8 on: July 14, 2012, 09:41:10 pm
Put mine in yesterday, I love them! I was tired of the dealership replacing them only for the bulb to fail half way home. Not the dealerships fault. I wish they would put them in stock and save a lot of hassle.  Plus they actually are worth having vs stock light bulb you can see in  the dark a foot a way.  It is all good though I am sure they have their reason over in India for not putting in led lights stock.
Signature
Reply #9 on: July 14, 2012, 09:46:03 pm
I'm sure the reason for RE not installing LED's is spelled "rupees".
When they are worth less than 2 cents each it takes quite a pile of them to buy a LED. :)
GlennF
Reply #10 on: July 15, 2012, 04:34:39 am
LEDS also draw less power meaning a better charge into the battery.
  • Global Moderator
Reply #11 on: July 16, 2012, 08:42:06 am
The problem is almost always a bad ground. LED's stock? That's heresy
www.cyclesidecar.com
Lwt Big Cheese
  • Getting there, slowly...
Reply #12 on: July 16, 2012, 10:09:43 am
I repaced the sidelights with LED's. They lasted one journey!
And yet LED's are more robust and durable! Put original bulbs back in and they still work!
That makes no sence to me.
No warranty implied or given.
May contain nuts.
gremlin
Reply #13 on: July 16, 2012, 01:37:32 pm
+1
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
ROVERMAN
Reply #14 on: July 16, 2012, 03:03:01 pm
+1 to Gremlin's +1. The pilot lamps are "case grounded" to the housing, remove the lamp and scuff up the contact etc.
Robert & REnfield.
GreenMachine
Reply #15 on: July 16, 2012, 03:42:16 pm
I cleaned up the main chassis ground behind the battery case last year with my dremel, cleaned the bulb sockets with electrical contact cleaner and put a dab of weatherproofing gel around the outside of the actual bulb (not the contact points) ..I just have the OEM bulbs and head light..I haven't lost any of the original bulbs yet (knock on wood for a 06)..I did purchase the entire replacement bulb kit over the winter as a resource when the need arises. I like the idea of the LED bulbs for their low current draw but I'm satisfied with durability of the existing bulbs too..If you find that your losing a light bulb of any type, you have a problem that needs attention..GM
Oh Magoo you done it again
bman734
  • If it smells nasty, don't eat it
Reply #16 on: July 16, 2012, 03:43:50 pm
My right pilot light went out just last week. I purchased a 1445 incandescent light from Advanced Auto Parts. $5 for a pack of two. My problem when trying to install was first getting the old bulb out of its socket. I finally got it out with  some pliers. My next problem was with getting them to stay locked in upon installing the new one. It just will not remain twisted in completely and I don't want to use pliers in fear of crushing the bulb as the bulb is the only thing to hang on to. finally got it as much as I could with my fingers and hoped for the best. So far so good after a couple of rides. Any suggestions on how to seat it more firmly without breaking the bulb?
Royal Enfield C5 Military
Suzuki SP370
Honda CX650
Yamaha XS650
GreenMachine
Reply #17 on: July 16, 2012, 04:00:25 pm
Those I never tackled but someone had written that they were a bugger to get out and then getting them back in place and secured was another issue..You would think a fine needle nose plier and a twist and direct pull out would be the way to go but its a Enfield..I haven't had to replace mine so maybe someone has a better idea on the subject.GM
bman734
Reply #18 on: July 16, 2012, 04:05:05 pm
Yes, getting it out was a problem but I could see it was burnt out so didn't care if I broke it. Now I do care with a new bulb so any "bright" ideas out there would be appreciated.
Suzuki SP370
Honda CX650
Yamaha XS650
gremlin
Reply #19 on: July 16, 2012, 05:23:47 pm
Use some tight fitting vinyl hose as a tool to install the bulb.
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
bman734
Reply #20 on: July 17, 2012, 11:53:59 am
Great idea Gremlin, I'll give it a shot.
Suzuki SP370
Honda CX650
Yamaha XS650
The Garbone
  • Shade Tree
  • User Complaints: 22
Reply #21 on: July 17, 2012, 03:46:37 pm
I put in LEDS, after the left one burnt out a few thousand miles later one of the guys at work comes up to me.
"Hey man, looks like your left light is burnt out."
 "Cool, thanks."
"What are those light for anyway?"
"Oh, them,  they burn out."
"No I asked what they are for..."
"Ya, they are there to burn out.."
"Oh."
The left light is still out and the right still lit. On my 95 the left screw was so corroded in it sheared off when I tried to remove it.  Now its missing an eyeball.
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
BrashRooster
Reply #22 on: July 18, 2012, 02:10:34 am
 :o did I show my age? We had electricity when I was growing up. So why doesn't the running lights use carbide lanterns instead?
 ;D  Ok yeah I guess I get what you mean about not having stock LED and it is a good thing even if the blasted things never make if home lit from my dealership, well the left one more then the right.  I do like the LED lights I installed and they are very noticeable if not correct.  Hey I want to brighten up my speedo can the light be replaced with the same type as the running lights and indicator lights (brights, neutral, turn signal)? I have issues at night with amber or yellow goggles seeing the needle.
Signature
Jamesriot
Reply #23 on: April 09, 2013, 07:18:06 am
 "Cool, thanks."
"Oh."
*sorry this is old post, but I need to dig it ;)
Hahahaha...cool joke bro! Thanks for sharing
Modenas Elit 150
HD Sportster 883
MZ Moskito 125
Suzuki TXR 150
Honda cup c70
no bs
Reply #24 on: April 09, 2013, 06:11:49 pm
#53 automotive bulb is a cheap durable replacement (ask me how i know).
Reply #25 on: April 09, 2013, 06:25:24 pm
I got the socket to of the hole when I replaced mine with LEDs. I think I pushed them out the front. Anyway I was looking at the sockets when I swapped the bulbs. They were a bit tight, but at least I could see what I was doing.
