Author Topic: Lithium Ion Batteries A Review  (Read 8906 times)
singhg5
on: June 30, 2012, 09:23:04 pm
Lithium batteries are now being advertised for motorcycles with advantages of light weight and good cranking power. Read this review of such batteries made by different companies, in Motorcyclist magazine.
Has any one tried them on RE or any other bike ?
1970's Jawa /  Yezdi
2006 Honda Nighthawk
2009 Royal Enfield Black G5
singhg5
Reply #1 on: June 30, 2012, 09:23:42 pm
Page 2 of Review
1970's Jawa /  Yezdi
The Garbone
  • Shade Tree
  • User Complaints: 22
Reply #2 on: June 30, 2012, 09:53:54 pm
I guess it depends on the chemistry.   I know that if they are cycled fairly deep the tend to pull a lot more amps than a lead acid battery.  I imagine if they have some type of regulator built in this might be a big issue.
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
Reply #3 on: June 30, 2012, 11:42:26 pm
After almost ruining my eyes trying to read the reports I noticed that all of these batteries ended up being rated at 3.7 Amp/Hr.
With the Royal Enfield UCE's 14 Amp/Hr battery rating requirement I wonder if these batteries would be suitable and would match the charging system?
I noticed they were conducting a 100 amp discharge test so I'm assuming the tests involved actually starting some real motorcycles?
I mean, they could have subjected the batteries to a 1 second or so Zap and said, "OK, there's another one!". :)
On the other hand for an Iron Barrel, AVL or UCE that is kick started I'm sure their batteries would have enough power to activate the ignition and headlight but at $160 + I'm not sure they are worth it.
REpozer
Reply #4 on: July 01, 2012, 02:06:29 am
I'm on my 4th year with stock battery. I use a battery tender.
Lead acid is working fine for me.
REA member # 84  (inactive)
jartist
Reply #5 on: July 01, 2012, 04:37:31 am
I think the main advantage would be size and weight on a cafe racer. Hide it in the hump behind the seat and remove starter gear for less weight. Ace fireball the engine and vavrooooooooom!
singhg5
Reply #6 on: July 01, 2012, 05:17:03 am
Place the cursor on the picture - RIGHT click the mouse and open the page in New Tab.
THEN place cursor on the text (in new tab). The cursor will become +, LEFT click and the whole page will expand further.
Letters will be the size shown in this sentence.
If you still want to enlarge it further, at the bottom of the computer screen usually there is a 100% size on the bar, that can be expanded to 200 or 300 or even 400%.  The letter become HUGE as shown here.
No need to ruin your eyesight !
« Last Edit: July 01, 2012, 05:25:31 am by singhg5 »
1970's Jawa /  Yezdi
Reply #7 on: July 01, 2012, 06:39:51 am
Well Schazzam! (Shades of Goober on The Andy Griffith Show). Thanks for the sizing instructions Singhg5. :)
jmiller_2308
Reply #8 on: July 01, 2012, 03:24:38 pm
So how would these batteries survive on the bikes charging system?  The second page indicates you want to charge the battery using a special charger and that makes me wonder what would happen under the normal charging system.
It also seems like this is apples and oranges.  The lithium are all less than 4 ah while the Yuasa is 10 ah.
Jeff
singhg5
Reply #9 on: July 02, 2012, 03:48:11 am
Yuasa YTX12BS is rated at 10AmpH by manufacturer. BUT according to the reviewer the ACTUAL value was only 4.2 which is close to 3.8 AmpH of Braille Lithium battery.  May be something about the way the batteries were tested.
On a similar note, Shorai Lithium battery for RE is LFX14L5-BS12  (They have it on their website -  http://www.shoraipower.com/s-327931-Electric-Start-500cc.aspx ). Its spec mention 14 AmpH lead equivalent .  The comparable Yuasa YTX14AHL-BS is rated at 12 AmpH.
I guess if SAME test is done by same method, both lithium or lead batteries show comparable ampHs, with very slight advantage for lead battery.
The other question, if the charging system of motorcycles or RE is compatible with lithium battery ?  That requires some digging and trial. It depends how good the regulator is in maintaing a narrow range of proper voltage / amp.
« Last Edit: July 02, 2012, 03:54:24 am by singhg5 »
1970's Jawa /  Yezdi
Reply #10 on: July 02, 2012, 06:58:57 pm
The article says they shouldn't be charged at over 13.7 volts. Most automotive charging systems run at about 14.5V. You can check the Enfield and see if it stays under 13.7. I will probably do it to mine in the next couple of days as I have a bit of electrical work to do. The 4th in the middle of the week is screwing up my RE scheduling! :(
singhg5
Reply #11 on: July 03, 2012, 04:06:39 am
You are right about charging systems running about 14.5 volts.
My G5 battery voltage had jumped to about 14.3 volts at higher rpms and stayed close to 13 volts at idle.
http://www.youtube.com/watch?v=p6GnwkCXPi4
1970's Jawa /  Yezdi
Reply #12 on: July 03, 2012, 06:16:44 am
The little multiple LED voltage indicator I installed on my G5 says the idling voltage is at 12 with the headlight on, 13 with it off.
At idle with the headlight on, the turn signals knocks the voltage down below 12.
Riding at 40-50 mph in 5th gear gives 14 volts with the headlight on and winks of 15 volts with the headlight off.
A link to the voltage indicator
http://nfieldgear.com/enfield-store/aftermarket-parts-accessories/electrical/led-battery-gauge.html
singhg5
Reply #13 on: July 07, 2012, 06:09:53 pm
Bare SCARE by 1 Volt  :) ! That would made lithium batteries unusable in motorcycles.
The article says they shouldn't be charged at over 14.7 volts (not 13.7 volts).
Shorai Lithium battery literature also states that they have the same charge requirements as AGM lead-acid batteries. They are direct replacement of OEM or AGM lead-acid batteries for motorcycles.
I will try Shorai Lithium battery LFX14L5-BS12 next time after my Yuasa battery runs out of steam.
« Last Edit: July 08, 2012, 11:17:45 pm by singhg5 »
1970's Jawa /  Yezdi
Reply #14 on: July 09, 2012, 12:44:26 am
Oops, my bad! 14.7 it is. Sorry about that.
