As some of you know I was looking for a used Harley muffler for my G5 and not having much luck. Well, I lucked out!
One of our nice members offered me one so I now have it. (You guys are the best!
I had to buy a clamp and a local Harley shop sold me a used one for $5.00.
As it turns out, the Harley silencer weighs 9 pounds less than the OEM silencer so in addition to the good looks the bike should go LOTS FASTER
The silencer comes with a stout mounting bracket on the side and this bracket is designed to take 5/16" carriage bolts. The kind with a short square under their rounded head.
Two 5/16 inch carriage bolts, two flat washers, two lock washers and two nuts later I was ready to go to work.
Being a nurdy engineer I measured the mounting locations used by the OEM silencer and fired up my Turbocad drafting program.
After giving it some thought I decided I wanted to use 2 brackets like the OEM's. One to the passenger foot peg bracket and one to the forward bracket just behind the rear brake pivot. Printing these drawings out at close to full size gave me something to compare my parts to so I could get the right offsets.
I used some 1/8" x 1" cold rolled steel from my local Ace Hardware store, a 3/8" drill bit, my hack saw, a vise and a file to cut and form the vertical bracket and I found a piece of 3/4" wide stock in my junk box to make the fore/aft bracket. (shown in photo 1 below)
I painted my new brackets with black Krylon BBQ paint that can take 1000 degrees F so that should last for a long time and protect the carbon steel brackets from rust.
Removing the old silencer isn't too hard but you should know that the heat shield locks into a tab on the exhaust pipe so it has to be removed to get the OEM silencer off.
The Harley muffler inlet is slightly larger than the RE's exhaust pipe so I had to make a sheet metal ring to fill the gap. For this I used a piece of 1/32" thick aluminum I had laying around. It is easily cut and formed and aluminum's melting temperature is over 1100 degrees F so it should be able to take the heat (I hope).
The stock for this ring should be about 1" wide and 5.340 long and trimmed so there is almost no end gap when it is tightly fitting the exhaust pipe. The end gap will be a leak path so take your time in fitting it.
I had to modify the Harley clamp with my Dremel tool with a cut off wheel installed by cutting off part of a short leg to get it to clamp the new silencer tightly.
Beyond that, everything went as planned so the silencer is installed.
I will polish out the yellowed chrome on the exhaust pipe but I think I’ll have to find/make a heat shield to cover up that ugly heat shield retainer and its uglier aluminum paint shown in the picture below.
This silencer still has the factory baffles in it and stamped on the side it says its loudness is 80 Db, the same as the RE’s OEM silencer.
My first ride with the new silencer shows that there is no backfiring on decel but the seat of my pants says the acceleration torque is less than with the OEM silencer.
It still pulls pretty good but not as strongly as it did before the change.
A high speed run shows the bike will still hit an indicated 80mph but its working harder to do it.
I think the old aircraft length 3/8" drill bit is going to attack some of the Harleys internal baffles.
