Well, you guys have my permission to form a circle around me, point fingers & laugh your fri**in' asses off at me.
After lunch I was sitting here listening to the latest lies on TV & suddenly like a bolt of lightning "Intake Leak"! shot through my heat-curdled brain. I'd like to say I read your posts, Areezonee & Green, before I thought of it, but I didn't. Honest.
So I went down & gave it a shot of carb cleaner & sure enough, the idle speed rose. What happened is I've had the carb off so many times that my attention must have got diverted or something the last time & the clamp wasn't final tightened. So just to be sure I pulled it, put a very thin coat of red Hylomar on the throat & tightened her up good.
Problem gone instantly & it's back to perfect again & a pleasure to ride. In fact I didn't even want to come home again, but it's too bloody hot for this old man.
Green, all your suggestions are good, but none of that stuff is wrong with this carb. I'm obsessive about stuff like that (except tightening the intake flange
). And I disagree with you on the difference in Pilot Jets, a 15 vs. a 17.5 - it made a huge difference on mine.
Arizoni, I had checked flatness before. Plus I put a very thin coat of UltraBlack RTV on it the very first time I ever had it off.
And the funny thing about this is that I'm used to dealing with micro-air leaks on shovelhead harleys. They are notorious because so many variables must be aligned perfectly for the whole unit to be air-tight. And there are TWO cylinders.
Anyway. It's really running good again now, in fact excellent. I'm very close to 500 miles now so a fluids & filter change, valve set, head torquing will be soon. And install my fancy little pushrod adjusters.
PS: Green, I've been using MMO since new; One Oz. to Two Gallons. I mix it in my garage. I hate gas stations.
Onward & upward.
