You seem to have a lot of problems getting your settings right.
Thanks mate, yes I can't seem to dial some things in.
I think I got my timing pretty well right. I still get a blue header pipe way down to the second bend when the engine is hot, which can indicate retarded, but when the bike cools the bluing fades pretty much all way. But the degree wheel and strobe timing light say its right.
I believe my carburetor is the key. I have heaps of advice on what jets to use but I still can't seem to get anywhere. It is a black art, tuning a carb.
I have a 27.5 pilot jet in there. I started with it 1.5 turns out from bottom. That gave me a good idle but the engine would die when the throttle was blipped. The engine would also die when 1st gear was engaged unless I rolled the throttle. Lots of popping on deceleration, especially down hill. That tells me its lean. So I screwed in the air bleed screw little by little until all those symptoms went away but my spark plug was black and furry. So I screwed it out again little by little until the symptoms were still gone but the plug was chocolate brown. So I think my idling and low range settings are good.
I have a P2 needle jet and the jet needle clip is on the bottom groove. I consider the bikes performance in the mid ranges to be good or at least good-enough. The bike feels powerful and accelerates up to 100kph (60mph) with no hesitations. I think the mid-range jetting/settings are good or at least good-enough.
The high range is my problem. When I get up to 100-105kph, I am at wide open throttle. That's not right. Most people tell me that with my setup (535 with 8.5:1 piston at 150psi compression) I should be only be around 1/2 to 3/4 throttle at 100kph.
I did some plug chops the other day. I got up to wide open throttle on the highway for 1 minute and killed the motor, pulled the clutch, drifted to a stop. My plug was a pinkish-brown. That was with a 127.5 main jet.
So I put in a 130 main jet and repeated the same test. No change to the plug color and I was wide open throttle for 1 minute. The engine had a tiny bit if stutter/hesitation at one point but it was gone very quickly.
So I have ordered a couple of larger main jets to see what happens. A bloke in the Enfield club here had a bike very similar to mine (535, 19 tooth sprocket, same piston, steel conrond, alpha roller bearing, japanese bearings in the cases, clutch springs 1/2 normal, 1/2 heavy duty, and the Mikcarb VM28). He told me he had to go to a 140 main jet before he got proper top end.
I forgot to mention I have a S&B cone filter on the back of the carb. My exhaust is straight through (no cat converter) but it does have the PAV system. I ordered a blanking nut from Hitchcocks to get rid of that. My muffler is the shorter Indian one. I live at sea level.
I'm not trying to make a crotch rocket out of this. I'm not into 'high performance'. But I rebuilt the engine into a 535 with the above mentioned mods to enable me to ride the highway and keep up with traffic when I can't ride back roads. I'm not a racer or a rev-head. I'm a sedate thumper that wants to have some "oomph" on tap when needed.
And to stay a little on topic, I'm using too much fuel at the moment.
Maybe I am targeting the wrong area and should be looking at the air flow into the carb rather than the jets?
The Secretary of the Treasury has forbidden the purchase of a bigger carburetor at the moment so I need to tune in the Mikcarb.
Thank for hearing my snivels.
