So I recently retorqued my engine head bolts for the first time in response to what I thought was a slow oil leak/weap from the head gasket. It wasn't, but I just realized after a long ride the other day that the oil feed bolt which goes into the side of the intake rocker had a few drops of oil on the outside, which seem to slowly be covering my engine.
It's a very slow leak so I'm not horribly worried about it, but I figured I'd post on here and see if anyone had any input as to the cause/effect of this situation.
Can I just tighten that big bolt to make the drip go away, or is there something else at work here? Also, does anyone know why they call it a banjo bolt? Because it's hollow perhaps?
Thanks in advance,
Chuck
