Author Topic: Primary Case Noise?  (Read 10577 times)
Reply #15 on: June 18, 2012, 03:18:53 pm
I don't have a AVL (have iron)..Yours is louder than mine..I have the basic clattering valves sounds and a bit of engine noise (Pretty much sounds the same to me since owning it in late 06)...Is it me or does your engine seem to idle at a higher than normal RPM...I hear that whirling chattering sound too in the first video..Didn't seem to notice as much in the second..I don't get the cooling off ping sound but then again, different engines...I would check that primary chain tension again while rotating..make sure the adjuster is secured to the base. while the cover is off spin the tire and listen .You can reuse the fluid if u catch it in a low turkey tray. ;D I'm assuming this mechanical sound recently reared its ugly head or u wouldn't be concerned....
Rob Vespa
Reply #16 on: June 19, 2012, 06:16:49 pm
Thanks for the advice.  I've only had the bike for a little over a month.  The noise has steadily increased during this time.  I didn't notice it at first.
Since I don't know what condition the bike is in, I've decided to drop it off at a local shop for a once over (and find out what is causing the noise).  While the bike is there, per suggestion, I may have the sprag/ES removed (if it isn't damaged, I'll save it).
« Last Edit: June 20, 2012, 05:51:54 pm by Rob Vespa »
| 2009 Royal Enfield Bullet 500 Deluxe AVL
| 2004 Triumph Speedmaster
Rob Vespa
Reply #17 on: August 25, 2012, 09:19:14 pm
Long time, no write.  I wanted to follow-up on this thread to let everyone know what happened.  There's a happy ending.
The delay was caused by my being out of town combined with having no help getting the bike to a shop.  After a few starts and stops, that was sorted out and I took my bike to the closet Enfield shop, Heindl Engineering.
We thought the main issue was the sprag clutch, which would need to be replaced or removed.  After digging into the bike, they found that a pushrod was loose.  Luckily, it didn't bend or damage anything.  I asked them to give the bike a once over, which was good, since they found other issues.  Example:  The noise at the cylinder head?  There was no exhaust seal.  The original owner must have had a different exhaust and forgot the seal when switching back to stock.
Props to Heindl Engineering. I got my bike back from the shop Wednesday afternoon. This is the first time I've used a shop and I was nervous. The service was quick and Dave and company went above and beyond.  They answered all my questions and took the time to show me a few things.
My bike is now running smooth. It's almost like a different bike.  Happy to have her back!
As a fringe benefit, while servicing a bike is no doubt expensive, the bill was less than the price of the part I thought needed to be replaced... and perhaps more importantly, the once over put my mind at ease.
Rob
ridgerunner
Reply #18 on: August 26, 2012, 12:49:08 am
On a different note, many of us use ATF in the primary instead of 20W50
08 Bullet ES (AVL)
Rob Vespa
Reply #19 on: August 26, 2012, 05:33:58 pm
Thanks.  I bought ATF type F for this purpose, but chose not to use it after reading in forums and Snidal's manual about ATF versus AVLs (due to ES sprag clutch issues).  Have you had different experiences?
ridgerunner
Reply #20 on: August 28, 2012, 02:42:36 am
With 20W50, I would find chunks of clutch material in the primary every oil change (2000-4000 miles). After changing to ATF, the fluid was clean and debris free after over 5000 miles. Yes, my sprag failed after 23,000 miles but that seems to be nearly inevitable on these bikes. Since I kick start 99% of the time, I am more concerned with tearing up the clutch than issues with the sprag clutch. IMHO
08 Bullet ES (AVL)
Rob Vespa
Reply #21 on: September 01, 2012, 04:58:36 pm
Did you replace the sprag or remove it?  I may switch to ATF F the next time it's ready for a change.  I've also been thinking about degreasing the gearbox and using oil there.  Then there are reliability/performance mods - exhaust, air filters, etc. - to consider for the future.  Right now, I'm just happy to ride the more-or-less stock bike.
  • Global Moderator
Reply #22 on: September 02, 2012, 08:35:18 am
Dave Heindl and his people are very good in the shop. I would take my bike to them
www.cyclesidecar.com
Rob Vespa
Reply #23 on: September 04, 2012, 03:23:35 am
Thanks, Kevin!  I actually recently took my bike in to Dave and company.  They were helpful and resolved several issues I wasn't aware of.  It was the first time I ever took a bike to a shop.  It turns out the noise and other issues were caused by a loose rod.  Luckily, the rod didn't bend or damage anything.  Also, there were a few things missing from the bike (e.g., seals), which they replaced.
