I still get sooty plugs with the NGK, especially on short rides at low revs around town, but the NGK helps with a few other issues like rough idle.
I am starting to suspect the occasional report of a UCE fouling plugs a lot may have more to do with crap fouling the injector than anything else.
As for kickstart, I use it all the time with no problems, definitely nothing has broken. Do you make sure you find TDC before kicking ? Because its a big single, if you just kick randomly without easing past TDC it puts a lot of stress on the mechanism.
