First, let me wish you a very happy Christmas ! And please forgive me not to have answered earlier (cold weather+ xmas gifts = homework)
Tom, I have looked at my cams, they effectively go on 5/8" shaft, but have 40 teeths.. the width of the lobs is 14.2mm. So it should mean the S cams won't fit.
I have in stock (certainly an old Bullet one, as it has too 40 teeths, and the lob the same width as the J2) an inlet cam that has 20° more opening than the J2 one, but no "S" logo.
Some datas :
The inlet port has a 1"1/8 mm diameter
The inlet valve head is 1.625" (effective diameter : 38.2mm), the exhaust one is 1.5" (effective diameter 35mm)
The exhaust port (at the pipe) is 35mm x 2
I have looked at the head, and the biggest diameter for both valves would be 1mm more.
The crankshaft is a brand new one, with 25mm shafts. The bearings I have got are, for the drive side : 1 x NJ205 (25x52x15)crank side, 1 x 6205 (25x52x15), separated by a circlip.
For the timing side a NJ2205 (25x52x18), and the bronze bush
All are FAG, C3 and have a bronze cage.
The compression ratio isn't determined for the moment, but the top engine is all cast iron.
I have some interrogations about the way to go :
- the possible compression ratio
- the use of the Bullet inlet cam (I don't have the exhaust one, and don't know if the Bullet has the same caracteristics).
- Should I open a bit the inlet port, and fit bigger valves, or is it ok like that (Bullet cam or original one)
- As the bearings are 10mm smaller than Bullet ones, will it be a weak point ?
To resume : will my J2 allways be a good old purring cat, or a roaring tiger
Anyway, BW, I'm in for a set of S cams that will go in my Machismo.
