I was lucky enough to pick up the last of the previous batch of these cams and I can wholeheartedly recommend them. They completely transform the way the power is delivered, allowing the motor to rev freely to over 7000rpm. I've got them fitted to a standard engine with a free-flowing exhaust and a flat-slide Mikuni TM32 carb and saw 23bhp @ 5000 rpm at the back wheel on a lean main jet. Significantly, the power curve was still rising when we stopped (we were really only checking the jetting so I'd asked the dyno operator not to go over 5000. I forgot to tell him to take it all the way for the power run so he stopped early!), so with the right jetting and a full run, there's more to come. That's with the standard piston and compression ratio, and a fairly conservatively-sized carb.
The engine is easy to start, idles very well - better than on the standard cams - and really well-mannered. Although the cam allows the motor to rev, it doesn't compromise the performance lower down so I don't have to thrash it all the time. I can still cruise around lazily, but now the performance I need for overtaking is there. Other than losing the valve-lifter (which never really worked anyway), there are no disadvantages to fitting this cam set. For anyone wanting to exploit the full performance of their AVL engine, these cams are a must.
By the way, I don't work for BW! I just like stuff that works, and these cams do.
