Hi again,
I really, really appreciate all the help you guys are giving me. I know I'm learning a bit slow and am repeating some of the suggestions given, bear with me.
I agree that the piece of "metal" in the picture is actually part of the gasket. It fits back in place perfectly. I'm baffled where the "puck" at the end of the rocker arm went to. I pulled the push rod out and looked in the side cover, no puck. I carefully looked around the bike, around the rocker arm, nothing.
If I understand all this right, I need to order;
1. A gasket set
2. A rocker arm or assembly
I see nfield.com has the gaskets but I can't find a rocker. Anyone know where I can order a rocker?
Chuk
