In the near future I will be changing out the front sprocket on my G5 for the next size up. I believe that goes from stock 17t to 18t, correct me if I am wrong please. I figure that while I am in there I will need to and should do a couple of other things. Things like change out the plastic pump gear. The question I have is, what else should be done? I am looking to gather the right parts for the sprocket job, parts such as the sprocket and gasket for the right side, a new chain, if I am doing the gear then I would need a new gear. Come on y'all, what else should I spend money on?
Samgar
