Turning the key on sends the same signal to the coil that the points do, so you get one spark. It's usually in some spot that's dormant and won't have any effect on the mixture, but occasionally it will be in a hot spot and you get the fart, as it were.
It doesn't happen often, but occasionally. I don't recall ever hearing of one starting, but I supposed it's possible.
