Well, hopefully Snowkid03 will post her thoughts on her Royal Enfield.
In the post linked below you can read some of her (and our) thoughts when she was shopping.
http://www.enfieldmotorcycles.com/forum/index.php/topic,13950.0.htmlBased on her posts, she is fairly short so she should be able to give you some good information.
The last I saw she had a battery problem but this is not common and the UCE bikes are proving themselves to be quite reliable if they are taken care of.
Whether a Royal Enfield is the best bike for you will depend a lot on where you want to ride and how you ride.
The new Unit Construction Engine models (UCE) made after 2009 are basically 1955 style motorcycles with updated fuel injected 2009 engines in them.
Like the old 1950 bikes, horsepower is somewhat limited so the top speed is only a little over 80 mph. Also like the old 1950 singles they have a lot of engine torque so they accelerate quite rapidly if asked to.
Their handling is quite responsive to steering input making them much easier to ride than the heavy cruisers.
They do take some looking after with things like lubricating the chain and changing the oil and filter. If you haven't done these kinds of things, no fear. The forum folks can help you with almost anything you might need to know.
I don't want to talk you into something you aren't prepared for so I will add that if you want a 100 percent reliable, never have to do anything to it, high powered motorcycle the Royal Enfield probably isn't for you.
If you are willing to do a little maintenance and want a lower powered motorcycle that draws attention wherever it goes the new Royal Enfields are probably just what you are looking for.
