Bougth the kit quite a while back from our hosts when on sale. Original silencer's developed a crack at the bend near the joint with the exhaust pipe. I printed out the Bulleteer's thread from 9/09 as guide, read a couple other posts.
Got the old exhaust system off no problem. Went to fit the exhaust & can't get bits to line up. Close but not quite. If I get the pipe in the head the brackets are off, I mount the rear bracket the front bracket & pipe are off &/or the brake pedal's in the way. This typical. From what I've read holes might be off slightly, this is more like needing a rubber mallet or a prise bar to get them on. Probably to get them off again. Want to avoid that. suggestions
