RE+Trailer_1
May 01, 2016, 06:12:51 pm
Author Topic: Bar end clip stuck in the bar  (Read 1214 times)
1 Thump
« on: June 29, 2012, 01:50:45 pm »
I have the EMGO bar end convex mirros. They do the job just fine and would like to keep using them on the clubman bars that I just picked up. The clip that expands on tightening the nut inside the bar is stuck inside the old handlebar. Any idea how I could get it out. I am thinking if I screw the bolt in a couple turns then tap gently with the hammer it would move the nut deeper into the handlebar and free the clip. Yay or nay ?
Re: Bar end clip stuck in the bar
« Reply #1 on: June 29, 2012, 04:57:20 pm »
It'll move it farther in, but whether or not it frees it is anyone's guess. I'd try some Liquid Wrench stuff in there before I'd beat on it.
1 Thump
« Reply #2 on: June 29, 2012, 05:22:33 pm »
Well the idea is to move the nut further down and hopefully free up the clip. But I m going to lube it up and try to yank it out (and not tip the bike).
1 Thump
« Reply #3 on: August 06, 2012, 06:17:45 pm »
Screwed in the bolt, gently tapped it in to disengage......Then push it back further behind the deep end of the clip...Tug the clip out. 30 seconds and done.
