Last night, after reading a few posts, I decided to double check my rear wheel alignment and rear brake settings. I had originally just set both snail adjusters to the same point, and figured that would be aligned, and did nothing with the back brake.
Upon inspection it just didn't look right, so I busted everything loose and have been working on it pretty much all afternoon. I've come to the conclusion that the wheel is straight, it's just closer to the right than the left. Does this sound right, it doesn't to me, but I cannot see anything out of place, and I'm sure I didn't miss anything. I didn't disassemble anything when I adjusted the chain yesterday, so no missing parts.
I measured from the center of the swing arm bolt to the center of the axle, and they're the same on both sides. The right side (chain) snail adjuster is at 16, and the left side is at 13. I tried using string & a ruler, but either the center stand or front fender keep me for getting a good reading. Anyone have any suggestions or pointers, or is the wheel actually just closer to the drive side? Any other way to check it?
