Get a cheap rubber welcome Matt and some contact cement.
@Scott - That is a good idea, I modified it a little. Thanks.
My G5 rubber pad on stand had two problems - it was loose so it shifts position (it is not glued to metal plate behind it) and secondly due to repeated strikes against the frame, the pad groove had cut through - exposing edges of metal plate that would hit the frame with a 'clunk'.
First I glued the edges of pad to the metal plate behind it. Then I glued a patch of bicycle tube on the rubber pad. The groove perhaps allows the stand to stay higher up than it would otherwise. Will see how this new arrangement works out and how long it holds.
One good thing that the rubber pad is attached to metal plate by a conical stud that passes through a hole in the center of plate. The stud was intact and kept the pad from falling off even if it was not glued to plate.
@Singh
Three years Mine's only been about 4 months ish. I might need to replace mine also.
@JVS - It is never a dull moment with a Royal Enfield, always something to do
