Enfield with Leaning Sidecar
36 Guests, 3 Users
pearcey2, singhg5, dickim
April 28, 2016, 11:04:21 pm
Author Topic: Just as the good weather arrives - speedo seizes solid - expensive!  (Read 5644 times)
Spitting Bull
Good weather has come at last, so my speedo decided to seize up at about 13,500 km.  The speedo drive on the front wheel, of course, was still trying to turn the cable, and the upshot of this was a stripped gear in the speedo drive.
So that's a new speedo and a new speedo gearbox.  While the wheel's out I might as well change the brake shoes and fit a new front tyre.  Ah, well - it's only money!
Tom
cochi
Tom, sorry to hear about  your speedo. You may want to look at the CMW catalogue. They have a Smiths reproduction speedo that's really nice.It's about $75.00. It looks great and I think it's cheaper than the original. I installed one on my 03 Bullet and like it very much. cochi:)
dogbone
 ::) Is it possible to get a speeding ticket on an Enfield ???  !!!
99 Enfield Bullet 535
Foggy_Auggie
Only in a school zone!  ;)
Fortiter Et Fideliter
t120rbullet
Yes, 20 over in a construction zone on the wrong side of a barricade.
CJ
Spitting Bull
Cochi - that's the very speedo I plan to get, but from a supplier here in the UK.  In fact - I was planning to go and get it this afternoon, but ran out of time.  Glad to hear that you have one fitted and that you rate it.
Tom
cochi
Spittingbull, I did not realize that you are from "across the pond" . It must be incredible to ride the Bullet in the country of its ancestors!  I have been wanting to tour England on  a motorcycle since I began riding. I'm a fan of English television and have been watching   " Last of the Summer Wine" for years here in the States. The village where it is filmed is simply wonderful . I hope to take a meandering tour of many of those enchanted villages.  Anyway, as for the  Smiths speedometer, it was very easy to install. However, the turn signal , neutral and high beam indicator lights had to be moved. I was thinking of just leaving them  off, but unfortunately, I'm a bit forgetful with the turn signals. I ended up placing them on the cowl right in front of the speedometer housing. I purchased three plastic lenses , green, yellow and red, (couldn't find a blue one for the high beam) and drilled holes to match. I then rigged the  lights that were in the old speedo directly under the lenses. It didn't come out too bad. The Smiths speedometer as the youngsters say here "is da bomb" . It really looks great.  :) cochi
Spitting Bull
Cochi - one of the pleasures of riding the bullet for me is riding on the "old roads" with bends, bridges and villages - just the kind of scenery you mention.  Those are the kind of road I always head for.
Smith Speedo copies - I have a question for you, please.  When you turn your lights on, and the speedo is illuminated by (presumably) the two bulbs left in the housing after you've removed the main beam and turn signal bulbs, can you see the red and green markings of an original speedo dial through the black, Smiths copy dial?  I got one today, and that's what I see. It looks as if the new Smith's dial is not a replacement, but a stick-on, and the illuminated dial looks terrible as a result.
What about yours?
Tom
cochi
Spittingbull, sorry I took so long in getting back to you. The repro speedometer I received from CMV has only one bulb in it. I have not ridden the bike at night as of yet. However,  the other night I turned the lights out in the storage area and turned the Bullet lights on. The speedometer light was very dim.  The numbers do  not shine through. The light comes through the periphery of the speedometer.  It was a bit disappointing . However, to be fair,  I think the add for the speedo mentioned this.  I don't ride at night very much so I can live with it. It's still a great looking piece.  Good luck. cocchi :-\
Spitting Bull
I agree - the one I have just bought looks spendid on the bike (but now I have to get an ammeter to match) and the fact that the new dial is screen-printed over the original one, allowing the original markings to shine through at night, isn't much of a hardship to bear.
Incidentally - if anyone has to remove the spindle nut to change a speedo drive unit, be warned - they tighten them up rather enthusiastically at the factory.......   :P
Tom
cochi
Re: Just as the good weather arrives - speedo seizes solid - expensive!
« Reply #10 on: May 09, 2008, 02:49:56 pm »
Tom, you read my mind. The next time I have a few extra  dollars I am going to order the Lucas ammeter!  cochi ;D
« Reply #11 on: May 10, 2008, 06:39:59 pm »
"the fact that the new dial is screen-printed over the original one, allowing the original markings to shine through at night, isn't much of a hardship to bear."
Easy rectification. Don't ride at night!!!!!
SRL790
  • 1954 350
« Reply #12 on: May 11, 2008, 09:00:11 am »
To quote Joseph Lucas, after someone questioned the reliability of his lighting systems;
"A gentleman does not motor about after dark".
Andy Wiltshire
Spitting Bull
« Reply #13 on: May 12, 2008, 04:12:54 pm »
Ah - good old Joe Lucas - "The Prince of Darkness!"
Tom
Spitting Bull
« Reply #14 on: May 15, 2008, 01:45:45 pm »
Well, the new Smith's replica speedo is fitted, along with a new speedo drive gearbox.  Fitting went reasonably well, with just a couple of hiccups.  Firstly the spindle nut which holds the speedo gearbox against the hub was REALLY tight and nothing I could think of would shift it.  It looked as if I was going to have to knock out the spindle and the wheel-bearings so I could put the nut in a vice and use a Stilson on the spindle.   In the end I was able to cut off the nut using a little cutting-disc on my Dremel.   Fortunately this was possible as the original (seized) speedo drive is made of plastic so it was possible to cut down into it and then sideways into the nut.  Needless to say I had to get a replacement nut and I didn't tighten it up half so much as they do at the factory.
The new speedo drive was a genuine Indian part, and so was the new speedo cable so it came as no surprise to find that the square end of the cable was too wide to fit into the square drive-socket on the speedo drive and I had to file it down to fit.  I think the RE must be the only bike in the world which has standard parts which don't actually fit each other. Ah well,you know what they say about the RE - if you don't have a sense of humour, you shouldn't have bought one.
Tom
« Last Edit: May 15, 2008, 01:47:22 pm by Spitting Bull »
