The dual-fire(wasted spark) ignitions allow you to use a tach that is set up for a single fire twin engine, on your single cylinder engine.
For example, on the Iron Barrel bikes, the stock ignition uses points, which are a single fire system which fires every other revolution of the crank. It would need a tach for a single cylinder engine that is single fire.
When we change over to the Boyer electronic ignition, it is a dual-fire ignition, sometimes known as a 'wasted spark" ignition This fires on every crank revolution.
So, you can use a tach made for a single-fire twin, when using this Boyer on a Bullet, because it gives two sparks for each 4-stroke cycle.
So, if your UCE engines have a wasted spark(dual-fire) system, then you can use a tach for a single-fire twin on it.
