I did a quick search, and read a few posts, but I didn't see an answer to my problem. Hopefully someone can give me direction. I have a 2011 C5, and I want to remove to bar end weights, for bar end mirrors I just recieved. I'm talking about the internal weights.
I removed the outer weights and allen bolts.The internal weights look like they're simpy pressed in, maybe with some sort of locking compound? I tried pulling them out with a 5lb. slide hammer, didn't budge. I also tried turning the allen screws all the way in and applying force, to see if I could get them to twist. Again, didn't budge.
I have alot invested in the mirrors, and I'm going to use them. The mirrors are keyed to their bar inserts, so I can't simply mount them to the existing weights. I guess bottom line, if I can't get them out without destroying the bars, I need new bars. Like I said, hopefully there's someone here with a simple solution.
