Big Red
May 06, 2016, 07:29:23 pm
Author Topic: UCE & AVL Oil Change Kits?  (Read 470 times)
B5er
« on: April 23, 2012, 09:31:25 pm »
It looks like the oil filters for UCE and AVL are the same. They come in kits from Nfieldgear.com. Are the O rings the same for both, too?  I have access to an AVL kit, but I own a B5 with a UCE. I'd rather use what I have than buy another UCE kit...
Many thanks.
Re: UCE & AVL Oil Change Kits?
« Reply #1 on: April 23, 2012, 10:00:39 pm »
I'm not sure if the O-rings are the same but you can usually reuse them for a few changes do long as they are still pliable and not damaged.
« Reply #2 on: April 23, 2012, 11:00:27 pm »
+1 :)
GlennF
« Reply #3 on: April 23, 2012, 11:59:54 pm »
Not sure about AVLs but I do know there are a few differences between my B5 and the G5.  The B5 oil filter cover has three bolts not two and the pressure plate for the oil filter is a single piece with an Allen key holding the brass plate onto the spring section.
