Eg18pE0PHQ[/url]
I have also heard of machining off the part of the guide that protrudes into the port and also boring out most of its thickness before removal so as not to damage the head.
Correct.
The valve seats are another part that is machined away too.
Every removal /installation cycle increases the size of the heads valve seat recess or the heads valve guide bore.
They are never a "drop in" of "prefit" affair.
Sizes are measured, expansion differences factored and dimensions are adjusted by machining to ensure the parts are proper fitting at running temperatures.
These are parts that head must shrink to fit and precisely so.
Doing things at less than or greater than the proper temperature range at at other than the right "machined to" dimensions ruins things quickly.
Guides/seats will not be snug at operating temperature or will be to tight at normal parked temperatures which can ruin a head casting .
