Good video, Singh. Well suited for everyone, either to see the necessary steps for the first time, aswell as skilled mechanics who just make sure about the details once more.
An addition: rubber brake lines must be renewed after 5 years (in cars, too!). If you have to change the fluid anyway, you could improve your brake by mounting a steel brake line. This will reduce the power necessary to pull the lever and so makes it easier to find the right brake point. Regards
Maturin
