Plug reading can be tricky business. The condition of the plug will show the most recent conditions it was exposed to. I dont think a short ride around will show anything you can refer to. You really need a handful of new, gapped plugs, a clear stretch of road and some time to do it correctly. Get the engine warmed up well, put in a new plug and then ride it up to a steady mid throttle condition, without lugging or over revving the engine, pull in the clutch and shut off the engine and coast to a stop, this plug would/should show your mid range jetting condition. start over with a fresh plug, this time accelerate at full throttle up to the a fair speed, ( thus the clear road) pull in the clutch, shut off the engine and, and pull over. This should show your main jet condition. Different engine loads will produce different readings. There are variations of this technique but this has worked for me. Tere was a previous post concerning fuel to the carb, make sure its getting there from the tank. Good luck, have fun, mtrude
