Jolly has all but stopped using oil.9800 miles.I have the breather mod from host.I have the duckbill burping on the chain.There is a very slight amount of oil on the chain,but nothing like there used to be.Have started oiling the chain.This began when I redid the feed lines to the head.Photos of this are in the gallery.The copper lines I used are a fraction larger than the original ones.I do not believe this is the cause.I did this because of continual breakage of the original lines.Jolly seems to run very cool.Valve clatter is as usual and the tappet adjustment rarely needs to be done.I have a 35mm Mikuni and free breathing intake and exhaust.Jolly is very peppy and always sounds perfectly "happy".It gets close to 60 mpg.Timing is set at the specs in Snydal.Starts up on one or two kicks cold.
Jolly will do 90 by the speedo.
All of this is cool,but why would the oil use drop.Never did use much.I do not get it.
Any thoughts?
