All of those are pictured in the gallery. Of course, that is somewhat in jest as you still have out which is which. Basically, there are only three engines options, iron barrel, AVL and UCE. There are a few Iron barrels that have a starter mounted on the of the front of the engine, the Sixty-5 (sixty year anniversary model with a 5 speed) and a couple of other late model ones, 2004 and later. The AVL engines (Electras) were built as an interim thing while Enfield developed their UCE (B5s, C5s and G5s). Most of the other names were trim changes. Although the lean burn and twin spark were minor engine changes in the basic three.
