Cyrus,
Aniket is at his daytime work right now.
I can give you some of the information.
Here is a pic of the castings, but the finish machining isn't complete yet.
This is the latest photo of the engine castings that I have seen.
They are cast in A356, and these pics are taken fresh out of the mold at the foundry.
The oil pump type is the Bullet positive displacement plunger.
The high volume types are used, and there are two of them.
Both of them are the large high volume return pumps, for most oil delivery.
They are both performing feed pump functions, one for each cylinder.
The engine is wet-sump type, so no return pumps are needed, and it just drains down into the sump.
The oil filter will be the canister type, and will use the UCE oil filter element.
The rods are side-by-side on the same crankpin.
The timing side bearing is enlarged, using a 305 on the timing side now.
There is a windage tray in the sump to control the oil surge and control any oil being dragged around the flywheels, more than necessary.
The engine breather is baffled, and located in the back top corner.
Valve lash adjustment is done under the rocker covers, and the pushrods will be upside down to facilitate the adjustment from the top.
The engine will have the tunnel across the oil tank, so that a left-shift 5-speed gearbox can be used. Or any right-shift Enfield gearbox.
There are only two sets of castings built at this time, and they are both pictured above.
The frame mods are likely to be about the same as the 700 Musket V-Twin, which required about 6" stretch in the top frame tube under the fuel tank. Engine mounting plates took care of the rest down below.
So, the wheelbase will be longer with this engine, than with the single.
Anything else you'd like to know?
