I am beginning to feel a little apprehension at cruising . This is of course suggesting that it is leaning up. This appears much better with the air bleed screw on the carburettor heat spacer full in. ----- What is that for?
Having the spacer off to look at it ,it simply allows air into the intake from the air cleaner via the adjustment screw.
I don't think everyones on the same page here.
On the home market (Indian) bikes they have an air bleed screw in between the carb and the head. On the 350 it's on the insulating spacer in between the head and the carb and on the 500 it's on the manifold where the PAV thing goes into it on US bikes.
From what I have been led to believe the thought behind it is you can lean it out to compensate for changes in altitude.
As you open it, it will lean the mixture out across the range from idle to WFO.
Don't use that to tune the bike.
Close it off completely and then do all your tuning 101 then leave it closed until you get up around 8,000+ ft. (don't know where it is for the bullet but my old HD was good up to around that with flatland tuning)
I don't think that little feature ever made it over to this side of the pond. Shame!
Also a 130 main would be 16 sizes larger than the stock 90 and way too rich for a 350.
A 105 main and a 27.5 pilot would be a good place to start with those mods.
The Indian Electras are not "lean burn/AVL" engines like they are in the US Electras, they are the old cast iron Bullet engine.
CJ
