Ooty to Coorg
July 29, 2015, 08:59:54 am
Author Topic: Performance Mods for AVL 500 (Machismo 500)  (Read 9504 times)
AVL Power!
Re: Performance Mods for AVL 500 (Machismo 500)
« Reply #15 on: April 24, 2012, 11:17:32 pm »
UPDATE!!
I got a new Mikuni VM34 Carb for my bike. Got that delivered today! Megaphone installed long back, UNI Air filter ready for use. I got the jetting specs for AVL 500 (VM34 carb Mikuni) once everything is set... I will install them.
Also, I think its nearly impossible for me to get the "S" Cams as VERY less amount of people in here heard about these. So I will work on this later.. maybe just try out other alternatives.
Once I am done with these modifications, I will work on the compression. Probably get new 535 pistons for my bike. But these upgrades will take some time as I need to save up pretty much for other things.
Thanks to everyone for all the info, especially Basanti and BW! :)
-Sanket
Bullet Whisperer
« Reply #16 on: April 25, 2012, 08:02:35 am »
I could probably get more 'S' cams made, the problem is they are not cheap to produce in small numbers, so a lot of money gets tied up whilst waiting to sell them all in order to recoup the outlay and a [small] profit. I had 6 sets made a couple of years back and sold them all, but apart from the odd enquiry, I have not seen enough potential demand for a second batch to be produced. These cams work very well, but not everyone who owns a machine already in the minority, where Bullets are concearned [AVL] wants to make these changes, so it's just lack of demand / high production costs that put the spanner in the works for this one.
 B.W.
AVL Power!
« Reply #17 on: April 25, 2012, 11:21:27 am »
I totally agree with you! :)
By the way.. If I have any small doubts on these mentioned performance mods then.. can I contact you via personal messages?
-Sanket
Bullet Whisperer
« Reply #18 on: April 25, 2012, 12:00:09 pm »
Hi Sanket,
 No problem, if you think I can help, ask away !
 B.W.
REpozer
  • Superfly and
« Reply #19 on: May 05, 2012, 07:23:39 pm »
Food for thought.
Best performance mod I made ,..was to loose 20 lbs. I understand that is not an option for everyone.
I was able to hit 80 mph (indicated) on a slight incline.
 Before the weight lose, I as only able to achieve 76 mph.
REA # 84 ( the first time)
AVL Power!
« Reply #20 on: May 06, 2012, 08:04:13 am »
Yes, weight reduction helps a lot. By the way..what do I remove from my bike? I don't use the E Starter.. So planning to remove the entire assembly. After that what all do I remove?
I would love to get some weight off my bike :D
-Sanket
REpozer
  • Superfly and
« Reply #21 on: May 06, 2012, 04:32:48 pm »
I didn't remove anything from the motorcycle. I ate less , and lost weight. :D
AVL Power!
« Reply #22 on: May 11, 2012, 07:59:54 am »
lol...
« Reply #23 on: May 11, 2012, 09:20:27 am »
           I weigh 140 pounds. I can't wait for the day when I can finally get the '08 Classic into 5th gear once in a while (right now she's got 369 miles) & do some REAL plug chops & get the old Mikuni dialed in the way it oughta be. I just gotta live long enough & get enough rainless days when I don't hafta cut friggin' grass.
2008 ACE Head AVL Classic
AVL Power!
« Reply #24 on: May 11, 2012, 03:14:42 pm »
140 is pretty good. I am somewhere near that weight range. Maybe a bit lesser than 140 pounds. Few days back I went for a short trip and had managed to do 88mph on a straight flat. Thanks to the "Rollie Free" position (minus the "rollie free outfit :P). I think the actual speed would be around 80~82mph.
By the way what Mikuni  carb you are planning to use? :)
-Sanket
AVL Power!
« Reply #25 on: June 21, 2012, 09:32:19 am »
Finally my VM34 is installed! Loving the round slides! Next goal will be the porting work and compression work :)
dustystranger
« Reply #26 on: July 12, 2012, 10:34:41 pm »
I think egli said you can make any carb work.  Ask Ace what carb he runs on his Bullet.  Yeah thats right a properly setup factory micarb.  Save your money and buy gas and tires.
AVL Power!
« Reply #27 on: July 13, 2012, 10:08:19 am »
Egli? He's a legend!
Also I think that Ace is running a TM32 instead of VM28 on his Fireball. VM28 would do good justice to my AVL but I want to make it different. Will be a powerhouse for sure!
Bullet Whisperer
« Reply #28 on: July 15, 2012, 02:12:37 pm »
Hi Dampking,
 Here is a pic of the piston crown mod I made, as discussed in the P.M.'s, which I couldn't add pictures to.
 B.W.
AVL Power!
« Reply #29 on: July 15, 2012, 11:38:54 pm »
Thanks a Ton BW!
