All the RE twins & singles that used the Albion 4-speed gearbox were made in similar fashion. The high gear with the ratchet teeth on the inside, may have wear on the teeth. The pawl has a little bitty spring and plunger to keep it ingaged to the high gear inner teeth. If the little spring breaks, it gives the symptoms you mention. That or a worn out pawl or spindle as was previously mentioned. All in all, it's not too hard to fix in comparison to other tasks.
