I do have some of that saved...
pasted in below- Mike
My set up on the old was a 27.5 pilot and 130 main. I have a K&N air filter with the
original bazooka drilled straight thru 9/16's. The elevation is 660 here in the prairie...
my mileage was 60+ mpg...
I started the flat side with the 140 main and and 38 slow jet.
(Mine came with 38 and 25 slow jets.)
LOVED the torque but was very rich and mileage down to 40...
I've worked my way down to the 25 slow and a 125 main with
the J-clip 1 ring above center... I think I'm very close with the mileage
in the mid 50's... it's hard to get a lot of miles in around here this time
of year with 20 to 30 mph winds and all the rain.
I had to buy 2- - 31mm M8 x 1.25 studs and nuts for the install. You will like
the fact that it is more compact so the sharp angle of the cable is reduced at
the top... it idles like a hondoodle; the choke is very awkward... the cable is just
a fraction long. With the adjuster all the way up at the top of the carb there
still might be 1/8th" slop...
That's bout all I got - Mike
28mm micarbK&NGoldstar Performance System with no baffle
27.5 Bottom notchStock(O8)125 main
30mm flatslide K&N Baffle removed from stock header pipe
19Stock2nd lowestStock 142
1) Needle on the 2nd lowest setting
2) 142 main jet
3) 19 pilot jet
I completely removed the awful dead spot and my plug is now a nice tan color. The only other modifications I have made to the engine, besides the new 30mm carb, are:
1) K&N cone filter
2) PAV removed
3) Baffle removed from stock header pipe
2) ~~~~~~~~~~~~~~~~~~~~~~
CMW has said it should be ready to go out of the box given my set up of 50's exhaust (I'm close to sea level here in NJ) with a 19 pilot and 140 main.
Micarb setup only….
Mine has freeflow exhaust, K&N filterin the modified stock air box. Mikarb w/ 125 /25 and the richer slide. running at sea level 40-80 degrees temp. The 80 degrees here a rarity. A fairly standard setup.
35 pilot 135 main and 4th notch on needle. Still needs a bit of tweaking but is close.
