Well now that I have more than 5k miles on my 2011 G5 and it was dry out this morning had a quick blast on the freeway. This first 10 months of ownership has been mostly uneventful. Reliability has be very good and only very minor teething issues , side stand cut-out killed engine on San Mateo Bridge on way to Monroe Motors to have speedo drive replaced (casing was split and seeping oil at time of first service replaced under warrantee). Couple of weeks back had rear wheel flat and on investigation found cause was corroded inside of wheel rim , not impressed! Cleaned inside of rim, sprayed with paint to seal rust and refitted tyre. Checking out source of stainless rims. And that brings me to how well it does it's job. Commuting to work , it's primary function, it gives 66-75 to the gallon (us) depending on traffic and if I hit the freeway. A run to San Gregorio on the coast was great fun and for an old school style bike it handles quite well. Brakes are nothing to write home about and I think a change of front pads to a sintered metal type will be in order . A steering damper would be nice especially on our interestingly paved bay area highways, this is the first machine in years that I have ridden which does not have one. Then there is the claimed top speed of 85mph (though the handbook suggest that one does not exceed 75mph) this morning whilst taking a quick blast to Union City traffic was flowing at a steady 75 , no problem (am adjusting for speedo error , it reads about 2mph fast). On the return a lane change required opening-up a little more and at 82 the rev limiter cut in.
