My ride
April 30, 2016, 01:51:51 pm
Author Topic: Leaky petrol cap  (Read 1240 times)
michigandon
Leaky petrol cap
« on: April 29, 2008, 03:45:10 am »
Anyone else have problems with the gas cap leaking on their Electra? The Mrs' newly-aquired '06 leaks like a sieve around the cap. My  >:( '07 Classic has a flip-style cap that seals up tight and appears to be  better made. Is it possible to retrofit the Classic cap onto the Electra tank? Should I try cutting out a different gasket first (have access to some heavy sheets of rubber here at work).
Any and all advice is greatly appreciated.
luoma
Re: Leaky petrol cap
« Reply #1 on: April 29, 2008, 06:44:05 am »
Mine leaks too.Drives me crazy. Someone a while back suggested that you make a rubber washer out of inner tobe or something, and put it behind the rubber disc already on it. I don't know if it would work but sounds good.
What I do is: don't fill it all the way to the top, and when closing it, be sure to give it a little extra push. It should click more than once to be fully closed. Even then, I get a little leakage around the cap sometimes.
  • Administrator
« Reply #2 on: April 29, 2008, 09:39:18 am »
An extra bit of rubber will do it, or... if it is under warranty take it to your dealer
President
Classic Motorworks
www.classicmotorworks.com
www.cyclesidecars.com
luoma
« Reply #3 on: May 01, 2008, 06:02:11 pm »
Thanks for the advice Kevin. My warranty just ran out, but I'll use a piece if innertube and make a rubber washer thingy for it.
scoTTy
« Reply #4 on: May 01, 2008, 08:48:28 pm »
yea.. that's a constant.. my wife has an 883 she changed the tank and her extra gas cap had a rubber washer that was , guess what?,, the same size.. no more drooling
