Reply #8 on: April 27, 2008, 11:31:17 pm
Whoa! the Enfield tranny is good , but not for the diesel. Ratios are all wrong for a small diesel. They don't have the throttle control of a similar gas engine or the power curve. U tube has videos of guys shifting the hell out of them and they crawl along at 40 mph.Comet style trannys will do that for you while you just keep the throttle pinned, they also can give you more than a 1 to 1 final drive, much needed for the low rpm power delivery of the diesel. The only thing the comet leaves you wanting is the kickstart, but my 6ld260 Lombardini starts easily with a rope and has an electric starter. It also has an easy to mount drive side bolt pattern. Perfect fo an industrial belt tranny, with minimal machine work. As you can see I power a generator with mine, until gas goes to $5 a gallon. Maybe next year?
« Last Edit: April 28, 2008, 12:38:50 am by cyrusb »
Logged
