22 Guests, 1 User
Bronwyncarlisle
May 06, 2016, 04:21:23 am
Author Topic: Raising the Needle on an Amal  (Read 2208 times)
Thumper
  • Psalm 23
  • Classic Wannabe
« on: July 25, 2007, 05:10:59 pm »
Hello,
Can you raise the needle on an Amal (32mm Mk1) 1/2 position by placing a washer under the clip, as you can on other makes?
I've never seen a clip like the 'butterfly' style on the Amals and wonder if it lends itself well to the shim.
If the answer is 'yes', are there special washers tailored for the application or should I scrounge around the workshop for one?
Thanks,
Matt
