Street Scrambler
37 Guests, 2 Users (1 Hidden)
May 28, 2016, 04:59:32 am
Author Topic: Speedo still dancing  (Read 1205 times)
luoma
« on: April 20, 2008, 02:56:31 pm »
I put a new speedo cable on and went out for a ride. The needle still begins to dance at around 60. It isn't as bas as it was in the 70+ range, but still irritating. Looks like I'm going to be shopping for a better speedo and/or sending unit soon.
birdmove
Re: Speedo still dancing
« Reply #1 on: April 21, 2008, 12:57:07 am »
  Don't know if my speedo dances at 60mph or not, since I haven't been over about 45 mph yet. If you can pull the cable itself out of the sheath/outer cable, you could try lubing the inner cable with something like "Sil-Glyde". Its kind of a clear grease like substance you could squeeze some out of the tube and coat the inner section with your finger and then slide it back in. Also, There are often speedo rtepair shops in a city. Tacoma, Wa has one, and Seattle used to.
    JOn
Jon in Keaau, Hawaii
