No, no 1098 for me. It's a 2005 749s with a 54mm Termignoni full system and a Power Commander ECU (in red, of course). It dynos @ 110 hp at the rear wheel (which I believe works out to around 130 claimed hp). I added 3 teeth on the rear sprocket as well, which was a lot of bang for the buck performance-wise. Somewhat controversial bike, I know - I happen to think they are beautiful. The performance is undeniably fantastic; track days on it are pure bliss (with a heavy dose of adrenaline!). I have it so dialed-in that I don't think I would want to trade if for a 1098. In any case, I have yet to really run up against the power or handling limitations of my bike (i.e., it's still a bit more bike than I "need").
At one time, my two bikes were a 1997 Ducati Monster 750 and a 1965 BMW R69S. Switching between the two bikes was always interesting. Going to the Ducati always made if feel like it was absolutely on rails, while going to the BMW felt like driving a delivery truck. If I had the free money, though, I'd get another R69S in a heartbeat; I just love those bikes. Beautiful and very easy to work on too - real straightforward, overbuilt, and German.
Going to a 22 hp (I'm guessing maybe 17 or 18 hp at the rear wheel at best?) bike with an early swingarm type frame is certainly a night-and-day kind of move. However, that's what my test drive last weekend amounted to. I arrived on the Ducati, rode the REs for about 30 minutes, and then departed on the Ducati. The transition was fun in both directions. I thought the RE was really a lot of fun to ride, and pretty comfortable too. The hardest thing for me to get used to was the placement of the footpegs on the RE. I used to have this same problem changing between the Monster and the BMW. The BMW had the added delight of swinging my shins into the cylinder heads at first too.
Your not kidding, t120rbullet, about the short wind up on the RE! The bike's entire performance range (5 gears in the case of my 2008 test rides) pretty much covered first gear on the Ducati. Still, it was well enough suited to the twisty back roads we were riding on. Going up hills definitely brought the relative hp deficit to my attention, though. I was reminded of how on old bikes, one needs to plan a little further ahead both in terms of maintaining momentum and braking a lot earlier. My only concern in this regard is how the RE will behave with a passenger (or pillion, if you like).
