I may be thinking about another Hitchcock pipe but I seem to recall someone here on the forum who got one of these pipes.
Rather than being the thick walled pipe that comes on the UCE's, it is a thin wall pipe with a larger inside diameter.
While common sense would say that larger diameter should increase performance, the opposite was true.
Low and mid-range power decreased and the engine still seemed to run out of power at the higher revs.
As I say, I'm going by memory so maybe whoever it was can jump in and tell me I am wrong?
Changing the pipe does change the bend and it does decrease the bikes total weight so there are justifiable reasons for changing it.
