Back country roads
41 Guests, 5 Users (2 Hidden)
solg, KD5ITM, Ducati Scotty
May 06, 2016, 03:47:17 pm
Author Topic: Ace UCE project.  (Read 49438 times)
iron.head
Re: Ace UCE project.
« Reply #195 on: May 23, 2012, 01:58:57 am »
Hi iron.head and welcome aboard.
Thank you Ice!
cool photos, what caused the abnormal wear ?  do both engines have approx the same history ?
Apologies gremlin-I am not sure of the reason of this wear. AFAIK it is due to poor running in.
Classic 500's sold in India do not have O2 sensor. Initial bikes suffered from missing/jerking/cold starts issue. RE issued a temporary solution in the form of higher heat range plugs and later Bosch Platinum Plus WR8DP plugs. Ultimately they have remapped all bikes with new maps which has fixed these issues and Platinum Plus is now provided in all C5's from the factory.
« Last Edit: May 24, 2012, 03:10:11 am by iron.head »
« Reply #196 on: May 23, 2012, 05:33:09 am »
Has anyone got a UCE head gasket laying around, and might be able to measure the thickness with a dial-caliper, so I can know the distance of the head from the barrel?
I just have the head only here right now.
iron.head
« Reply #197 on: May 23, 2012, 08:31:29 am »
Hi ace.cafe
I would love to help and can go to RE ASC tomorrow or the day after and can ask them to show me a new UCE head gasket, but I do not have a dial-caliper. Is there any other commonly available instrument which can be used to measure the thickness? Can a ruler be used?
« Last Edit: May 23, 2012, 08:34:30 am by iron.head »
« Reply #198 on: May 23, 2012, 09:23:47 am »
Hi,
I suppose you could use anything that could read pretty accurately at that size.
It's probably thin enough that you'd have to use a ruler with very fine graduations.
I suspect it could be in the area of about 0.5mm-1.0mm.
Any vernier caliper could do it, or a micrometer, or a very finely graduated engineer's ruler. The more accurate the measurement, the better. But anything close is better than nothing.
If you have the time and inclination to try it, I'd appreciate the help for the cause!
« Reply #199 on: May 23, 2012, 09:51:35 am »
Head gasket is 1.0mm.
« Reply #200 on: May 23, 2012, 11:24:02 am »
I'm not happy with the engine management of mine ( 2011 B5 + O2 sensor (US 49 states))
I think it runs too rich on the highway ( 7/8 ~ 8/8 throttle ).    I'm *really* looking forward to the work ACE is doing here.  If we can get the throttle down to something like 70% when cruising at 75 MPH I believe the system will re-enter closed-loop mode and start reading the O2 sensor to trim the mixture.
IMO, YMMV,  standard disclaimers apply  ....   :o
Thank you Ice!
Classic 500's sold in India do not have O2 sensor. Initial bikes suffered from missing/jerking/cold starts issue. RE issued a temporary solution in the form of higher heat range plugs and later Bosch Platinum Plus WR8DP plugs. Ultimately they have remapped all bikes with new maps which have fixed these issues and Platinum Plus is now provided in all C5's from the factory.
« Reply #201 on: May 23, 2012, 11:52:32 am »
Thanks you, Scott!
« Reply #202 on: June 12, 2012, 02:38:22 pm »
Vroom .... Vroom .....
Fogrunner
« Reply #203 on: June 17, 2012, 03:06:22 am »
 I just received my 2012 G5 Classic here in the Philippines and I am waiting for some know-how on how to increase performance!! Looking forward to more!! Any updates or progress? Great read.
Phil
Phil
2012 G5 Classic
« Reply #204 on: June 17, 2012, 07:35:15 am »
Phil?  From the Phillipines?  Really?  That is so cool!
JVS
  • I love chicken
« Reply #205 on: June 17, 2012, 07:39:26 am »
Scotland  :-X
Fogrunner
« Reply #206 on: June 17, 2012, 08:03:21 am »
Yeah, I put the Phil in the Philippines!!
Phil
2012 G5 Classic
« Reply #207 on: June 17, 2012, 09:46:59 am »
Our main guy who does most of our work at Mondello's has been on vacation for the last 2 weeks, so not much happening until he gets back.
Basically, there will be a number of experiments to see how the head responds to various things, and then some decisions will be made about proceeding.
"Bang for the buck" will play a large part. There's always a sweet spot on the "diminishing returns" curve that we like to aim at.
One thing that looks potentially promising is that we may be able to use the Fireball valve spring system in this head, with some seemingly "minor" adjustments.
« Reply #208 on: June 18, 2012, 01:38:55 am »
I would not move the O2 sensor. It is placed where it is placed for scientific reasons and is very important. No amount of "mind grinding" is going to change that. I have had this discussion with the engineers from RE and Keihin. It is also placed so that it sheds the maximum amount of moisture which can contribute to failure.
Where did we get the idea that the bike is not in closed loop operation at higher speeds?
Chasfield
« Reply #209 on: June 18, 2012, 05:46:35 am »
I suppose it wouldn't lead to a legally saleable product but I would be fascinated to find out what a developed UCE motor would produce with a good quality flat slide carburetor bolted on and all the EFI gubbins stripped off.
2001 500 Bullet Deluxe
