Hi all
Prior to the purchase of the C5 I read all info I could on better running of the R.E. C5 motor. Once I got the bike I removed the Bosch plug and replaced it with the NGK BRP6ES
The bike started and idled better but once i was on the road by about 2 or 3 miles it was breaking down and not running well. If fact the motor smelt HOT.I put up with this on the first few runs or about 10 miles. Same experience every time.So I the went back to the standard Bosch plug.Ran much better with this bike.
Unfortunately it ran fine for about 50 miles/80 kl and yesterday when i rode the bike it was again running rough.
I took out the plug and it was Vera very black/wet. Cleaned it up then put it back in the bike. Although good it never idled as good as the NGK
Maybe the NGK BRP6ES is not suitable down under ( as the motor smelt hot) I was thinking same NGK plug but a different heat range might be the go
So any ideas in the NGK heat range - Thought about numbers 5 or 7 or 8 - etc
I was out in my car yesterday a mazdaspeed miata. I said to the wife this cars fun but there's a lot of difference and fun factor from a convertable to a motorcycle.
Really like this bike and the thought one day it will be completely run in and the to cruising the back roads
Thanks in advance
Regards
