Congrats on the bike. Many improvements are possible.
This is the Watsonian Goldie on my G5. It gives a definite performance boost, but it's LOUD! Wait until the bike's broken in....
Fitting is straightforward, but you'll need the short 10 degree bend piece from Hitchcocks - the one from Watsonian is too long and requires the front pipe to be cut - bad idea if you change your mind later. Or it can be fitted straight on without the upsweep. You'll also need a heatshield to cover the join
That's an old picture - I've since removed the saddlebags & rear rack, but retained the tool roll. Grab handle is now chrome and there's a straight crash bar and twin Stebel Magnum horns on the front.
Tyres replaced by AM26 RoadRiders - recommended if you like it a bit quick through the curves. Stock mirrors replaced by Luis American Ovals (those shown are Hitchcocks - sent back because they slip about!). Headlamp is Tribar black dot halogen.
Notice the LEDs in the pilot lights. Also fitted in the speedo lights - turn, neutral etc.
Coolest looking Royal Enfield I ever did see.....
